Handlebar Diameter
Posted: Wed Jun 10, 2015 9:21 pm
by Boreham
Could anyone advise the ID of the GP clutch and throttle bar ends, i wanted to order some bar end weights/extensions but the headset is at the sprayshop
Cheers
Re: Handlebar Diameter
Posted: Wed Jun 10, 2015 10:38 pm
by corrado
1 inch. Motorbike bars are generally 22mm so most bike bar ends don't fit well.
Posted: Thu Jun 11, 2015 4:32 am
by warts
I think quite a few Harleys and metric cruisers use 1" bars.
Off road/ADV bikes with alloy bars too?
Posted: Thu Jun 11, 2015 12:04 pm
by shocky
I welded small discs on my bars drilled and tapped to 6mm and used some cheap aluminium bar ends cost under 3 quid from china , they had rubber bungs onthe end that when you tighten up expand inside hollow motorcycle bars I didnt use those bits ill try and upload some pics
Posted: Thu Jun 11, 2015 12:12 pm
by shocky
Sent from my C5303 using Tapatalk
Posted: Thu Jun 11, 2015 12:14 pm
by shocky
Posted: Thu Jun 11, 2015 8:42 pm
by Boreham
Cheers Shocky, a good alternative and theres loads of option options available
Posted: Fri Jun 12, 2015 9:01 am
by Donnie
You are aware that you'll have to cut the throttle and gear rods, shorten them and do some fabrication if you want to fit the internal fitting ones?
