Throttle cable
Posted: Wed May 27, 2015 8:29 am
by jamjo
Hello all , has anyone got any advice on throttle cable routing for a Mikuni TMX under a Oiltek long range tank(ts1kit) . Although the carb fits in the cut out great im not too happy about the angle of the cables coming out to it . Was going to get a angled adjuster to help but also what direction is it best to come to the carb (smoothest route )
Any advice would be great
Regards James
Re: Throttle cable
Posted: Wed May 27, 2015 9:42 pm
by Boreham
Hi James, i run an extra long cable around the back of the tank (between the tank and frame tube) with a 90degree bend on the carb, works fine
Re: Throttle cable
Posted: Wed May 27, 2015 9:48 pm
by jamjo
Hi Boreham, that sounds my solution im going to order a longer cable and a 90 degree bend and give it a try . Thanks mate :D
