starting issue
Posted: Mon May 25, 2015 1:30 pm
by LI150
I'm running a 200 engine with a 25mm carb through the air box it starts first kick runs great except when I have rode it if I go back to it an hour or so later its a bitch to start its as if its flooded. I have to get it running turn of fuel tap and burn of excess fuel for it to run right. If left overnight its fine any ideas
Re: starting issue
Posted: Mon May 25, 2015 2:06 pm
by mick1
sticking choke/not closing properly
Re: starting issue
Posted: Mon May 25, 2015 2:17 pm
by DaveTomo
spit back collecting in the hose? mate of mine had the same issues with a 25mm carb/hose and through the airbox, copied this no problems since
http://www.ilambretta.co.uk/forum/viewt ... 5mm+thread
Re: starting issue
Posted: Mon May 25, 2015 3:09 pm
by dave411
Good idea,but I think I would route the pipes further away from the exhaust,,,,,,,just in case.
Re: starting issue
Posted: Mon May 25, 2015 4:20 pm
by LI150
Great answer great solution cheers
