Page 1 of 2
Home boring/honing
Posted: Sun May 24, 2015 10:11 pm
by lambro
After years of dropping bits off at at various 'specialists' for re-boring/honing, and them never meeting the timescales promised,
which means rebuilds are delayed yet further
It was a welcome relief to find this chap on youtube that shows these can be home done jobs.
Not knocking guys like Simon at 'B' race etc, but with a few hours work, and some home brew tools, it is now possible to complete these jobs at the home garage
https://youtu.be/bT1nRq-cM7M
Shaun.
Re: Home boring/honing
Posted: Sun May 24, 2015 10:23 pm
by Muppet
if only i had the tools
Posted: Sun May 24, 2015 10:33 pm
by Dimitrios_231
Every day is a school day
Posted: Sun May 24, 2015 10:59 pm
by Juan
Shaun, see if you can get ahold of Rhys on smallframes. He got me a tool from his company a few years back that's considerably better than a few placcy spoons with a bit of wet and dry pasted on.
Posted: Mon May 25, 2015 2:52 am
by onthelam
I laughed at the swarf from the "cutting" process. But the spoons are creative. To de-glaze bores I have uses a piece of emery cloth in a hacksaw slot in a 1/4" rod in an electric drill.
Then again I have also squatted inside a cylinder
with a 4" grindstone on a flexible shaft.
to remove the lip so the piston can be removed from the top.
Posted: Mon May 25, 2015 9:30 am
by wack 63
What a load of bo**ocks
Posted: Mon May 25, 2015 9:43 am
by eden
lol
great
Posted: Mon May 25, 2015 9:44 am
by lambro
As long as no one is taking his video seriously
Made me laugh, 'specially the tennis ball,
And when he said not to bore it too fast with the plastic spoons incase you overheat the barrel
How fast would you have to turn that manual drill
Posted: Mon May 25, 2015 10:23 am
by Adam_Winstone
This must be the same guy that half of the dealers send their work off to, judging by some of the barrels that I've had done. Thankfully, there are some excellent UK dealers though that must sub it out elsewhere or do it well in house.
Thanks for sharing.
Posted: Mon May 25, 2015 11:34 am
by B-Race Tuning
This method works well, but where he's on about not overheating the barrel, he's fighting himself by using paprika as a cutting compound. Much better to use cucumber paste. And using a tennis ball is also a 'fault', as they are now designed to go much faster than they used to be. Again, and it's just my preference, much better to use a hamster, and feed it until it's correct bore size. Simon.
