Hydraulic operated disc brake problem!
Posted: Sun May 24, 2015 3:30 pm
by kevspeed
I have decided to use an old school hydraulic disc set up on my series 1with a 'hidden' master cylinder,it has been used before but using the motorcycle handlebar mounted master cylinder.
The problem im experiencing is that i cant seem to get the master to push out the slave piston.There is fluid getting through,and ive tried using a syringe to bleed from the slave end,and the conventional way,with a tube in a jar of fluid,any thoughts????
Re: Hydraulic operated disc brake problem!
Posted: Sun May 24, 2015 4:47 pm
by rosscla
How tight is the piston in the slave unit can you move it in and out by hand ?
Posted: Sun May 24, 2015 5:44 pm
by kevspeed
Pretty tight,but its been used,so i wouldnt have thought its an issue!
Posted: Sun May 24, 2015 5:59 pm
by wack 63
I'd strip it and check the seal and groove then pop the piston in without the seal to check it's free. The seal may have swelled
Posted: Mon May 25, 2015 8:23 am
by kevspeed
The thing is,there is no resistance at all at the lever,there is fluid getting through,but no pressure!
Everything is tight,so no leaks,so is there a way of testing the master?
Posted: Mon May 25, 2015 8:47 am
by wack 63
I've only done one on a Smallframe but I seem to remember it bled easy enough, I think I worked the piston lever by hand with the banjo bolt just undone a tad to pump the fluid out then tightened. The braided hose is a pain to bleed as once air is trapped it's hard to shift without pressure to force it out.Image
