series 2 electrics
Posted: Wed May 20, 2015 10:57 pm
by wrecklessrobbie
I am on with rebuilding my eibar s2.
I have a 12v electronic stator and flywheel. I have bought an electronic wiring loom from AF Rayspeed.
Can I run the lights etc with a kill switch and handle bar switch or do I need to buy a new key operated switch? Will it fit into the s2 headset?
Who would you recommend for the switch?
Robbie
Re: series 2 electrics
Posted: Thu May 21, 2015 6:16 am
by Toddy
quick answer, the choice is yours kill switch or ignition as long as you have the correct handlebar switch, ive used casa ignition switches , good fit and work fine
Posted: Thu May 21, 2015 6:37 pm
by wrecklessrobbie
Ok thank you for the reply.
What switch do i need? I have a series 2 one at the moment.
A while back i was in my waggon travelling from hemingbrough to howden/ m62.
I followed you until you turned into howden. You were doing a healthy 45 all the way.
Posted: Thu May 21, 2015 7:54 pm
by Toddy
wrecklessrobbie wrote:Ok thank you for the reply.
Running in
Posted: Thu May 21, 2015 9:39 pm
by wrecklessrobbie
It was also windy as a windy thing that day .
Posted: Fri May 22, 2015 9:13 am
by HxPaul
wrecklessrobbie wrote:I am on with rebuilding my eibar s2.
Robbie
I have an Italian series 2 running on a 12v system.I fitted an ignition switch and run all the electrics from that ie. ignition,pilot light and headlght.I use the standard handlebar switch but converted it so that I can use just dip/main beam and horn.
Posted: Sun May 24, 2015 9:05 am
by lammydave
if you are looking at decent ignition switches, the new ones from scootopia are excellent and cheaper than casa
Posted: Sun Jun 07, 2015 6:53 pm
by wrecklessrobbie
Ok thanks guys.
I may yet still use the kill switch. I have been stripping and rebuilding the kill switch and light switch. Both have come up well, in a rusteration looking sort of way.
Next question
Can i use a 25mm dellorto with a series 2 airbox.
Do i need to drill holes in the airbox. If so how many?
