Carb choice - advice please
Posted: Mon Jun 15, 2009 9:48 am
by newmanlammy
Got a GP150 engine bored to 175 and ported by Dave Betts (rip) with a scorpion pipe currently fitted with an old 28mm dellorto that runs but is not set up properly and looks rough anyway on a new engine so made my mind up to buy a new carb. Whats my best bet for this engine for smoothness, ease of set up/parts and value for money.?
Re: Carb choice - advice please
Posted: Tue Jun 16, 2009 10:55 pm
by soosh
It will still be ok with the 28mm Dellorto but just get a new one as there cheap as chips.Ive got a spec for this if you need it,just send us a pm or something.Or a TMX27 Mikuni.I personaly wouldnt run a 22mm through airbox but they are popular if you want original looks but if you have panels on then it doesnt realy matter.
Posted: Tue Jun 16, 2009 10:57 pm
by sean brady scooters
get a new 28/30mm delly................... :D
Posted: Tue Jun 16, 2009 11:39 pm
by Jet200
soosh wrote:Ive got a spec for this if you need it,just send us a pm or something.
Soosh, could you post the spec in carb set ups sect as I too have similar set up to Newmanlammy and can't yet get it quite right, cheers :|
Posted: Wed Jun 17, 2009 9:34 pm
by soosh
Ok
Posted: Thu Jun 18, 2009 9:45 am
by newmanlammy
As the general concensus is 28/30mm delly wheres my best place to buy one from mail order ?
PM if nec.
Posted: Thu Jun 18, 2009 8:33 pm
by tavspeed
i ran af stage 4 175,scorpion pipe,li 150 box,15 tooth front sprocket with a pwk 24mm flatslide,it was easy to set up,similar to a mikuni and the engine was quick for a 175,good little carb,small and light,and cheap,and you wont have to worry about the carb falling off or splitting the rubber, the carb rubber should last forever due to the lightness of the carb,cheers all.
Posted: Mon Jun 22, 2009 1:24 pm
by newmanlammy
Any more offerings before I go out and source a 30mm delly or 30mm Scootrs special
Posted: Mon Jun 22, 2009 1:47 pm
by drunkmunkey6969
Spend the extra and get the Delly.....quality is better, spares are plentyfull, and known jetting settings are easier to come by.
