Page 1 of 2
Scootopia Big Bore
Posted: Mon May 18, 2015 6:35 am
by grimspeed
Anyone tried or dynode one of these back to back with say a BGM or other big bore's ?
Re: Scootopia Big Bore
Posted: Mon May 18, 2015 5:00 pm
by Timbo
Never understand why there are not more reviews and tests in Scootering Mag. Same engine but differant pipes etc..
Posted: Tue May 19, 2015 1:54 am
by onthelam
^ I think because everyone's desires, needs and requirements are different. But I do understand your sentiment. Probably the best way would be to go riding with some mates and see who has what and how it performs for them. OR just buy one and see what it is like. If you don't like it buy another. This is what two stroke racers do. But they have a captive group of guys to study.
Here is what one man said!
Exhaust: TSR do an expansion pipe we have tried, well made and cheap at around £160.00, well worth a look.
Posted: Tue May 19, 2015 8:07 pm
by grimspeed
Well I bit the bullet and bought one .
Looks good in comparison with the Indian one's !
ie AF and KBA . Two piece u-bend with spring connectors.
And it comes with a gasket and clamp and a spring pulling tool .
£120 to the door direct from Scootopia.
Longer inlet cone from the U-Bend to the box like a Ancilotti !
I intend to run this on a STG 4 185 cast iron kit with a 24mm Mikuni .
Just have to wait and see now!
Posted: Wed May 20, 2015 5:04 pm
by dave wheeler
got one on my tv175, 24mm phbl, electronic and cyclone box, otherwise standard, not too noisy, seems well made and happy with how it goes, would love to see a direct comparison with a mb clubman, but the werent available when i needed a pipe
Posted: Thu May 21, 2015 3:24 pm
by corrado
It looks like it was based on the Ancillotti so a decent saving on cost. Decent build quality too.
Posted: Sun May 24, 2015 9:03 am
by lammydave
just bought one, and about to fit it to my RT195 kitted scoot....
I will report back, hopefully by Wednesday....
Could well be selling a JL3 if this one works out....
Posted: Sun May 24, 2015 10:04 am
by Timbo
Make sure you bolt it underneath the crank case (MB bgm experience)......interested to know what you think..
Posted: Sun May 24, 2015 10:42 am
by dave411
Is it important to bolt under the crankcase?
My Li doesnt have a hole there.
Posted: Sun May 24, 2015 10:58 am
by bristolmod
Innocenti put the tapped hole in the crankcases during the S3 run due to fracturing problems on the end tail pipe and the front bracket. Does help and gives a more secure fitting.
It is possible to drill the casing on earlier cases, but I think it means moving the additional bracket on the exhaust to line up with the newly drilled hole (The factory tapping was in a different place to the only available place for the DIY mod.)
I'm running an early TV175S3 and haven't bothered- no problems to date despite my home-brew 42mm Clubman/ chrome outrigger set up (looks plus Clubman power and that oh so good "pop pop" sound!!
There is also the danger of drilling too deep!
