Bad cold starting GP200
Posted: Sat May 09, 2015 10:47 am
Funny one this, having problems starting from cold (overnight) will not start unless I put my hand over the carb mouth to start, carb is 30mm Dellorto open mouth which is new, choke is working, thought I had cured this with a 55 pilot jet, checked the stator wires and the green/white is showing 445 would this be a factor, as it should be 520, can`t think of anything else, nothing obviously wrong apart from stator, when warm it runs and starts ok. Almost beaten me.
