12v bgm stator, what loom.
Posted: Sat May 02, 2015 7:33 pm
by idc23
I have fitted a 12v bgm stator, bgm reg, i have used the original 6v loom, the lights are so dim , brake light ok, but side & headlamp are crap, do i need to change to 12v loom, this is a series 3.
Cheers Ian
Re: 12v bgm stator, what loom.
Posted: Sat May 02, 2015 9:46 pm
by rosscla
Wire is wire there no such thing as a 6 or a 12v loom.
You probably need to check your existing loom for continuity / resistance , 50 year old copper wire can corrode inside the sheathing. Check the resistance on each wire with a multimeter. It should be 0 or close to. Any more and it's suspect.
Also check your earths.
How is the magnetism of your flywheel / what type is it?
Posted: Sun May 03, 2015 10:40 am
by idc23
New sr lightened f/wheel. :?
Posted: Sun May 03, 2015 12:18 pm
by rosscla
Ok if stator and flywheel are new then look to the loom and earths for high resistance values.
Posted: Sun May 03, 2015 4:52 pm
by idc23
Ok thanks for your help. ;)
Posted: Mon May 04, 2015 12:42 pm
by corrado
It always amazes me that with the myriad of electrical issues people face the last thing they will replace is the loom and yet it's the cheapest item in the link. BGM loom is less than £20.
http://www.lambrettaspares.com/spares/b ... m0318.html
