Page 1 of 2
Mugello timing
Posted: Fri May 01, 2015 10:23 pm
by Strummer10
Guys, just strobed a muggy 185 to 17 degrees BTDC and up the rev range it sits on the mark fine but on tickover its a good 2 to 3mms right of the 17 degrees mark. Is that normal on a muggy, just that I don't recall my set ups being that far right of the BTDC mark on tickover ?
Re: Mugello timing
Posted: Fri May 01, 2015 10:26 pm
by rosscla
The type of kit shouldn't have any impact on the behaviour of your firing point.
Re: Mugello timing
Posted: Fri May 01, 2015 10:34 pm
by Strummer10
Yes agreed. I know I had timing issues on the really lightened AF flywheels before with the timing jumping about and inconsistent but this set up uses an SIL mid weight flywheel and they should be fine. It runs ok otherwise....
Re: Mugello timing
Posted: Fri May 01, 2015 10:40 pm
by Strummer10
must admit the muggy can throw out some power....
Re: Mugello timing
Posted: Fri May 01, 2015 10:52 pm
by rosscla
I can never work this out, does that mean the timing is more like 20 degrees at tickover?
Re: Mugello timing
Posted: Fri May 01, 2015 11:04 pm
by drunkmunkey6969
rosscla wrote:I can never work this out, does that mean the timing is more like 20 degrees at tickover?
3 deg to right of 17 deg is 14.
3 deg to left of 17 deg is 20
Re: Mugello timing
Posted: Fri May 01, 2015 11:32 pm
by rosscla
Ah wrong way then...
Re: Mugello timing
Posted: Sat May 02, 2015 5:07 am
by Strummer10
yes its nearer TDC, so about 14 degrees. BUT on higher revs all way up a consistent 17 degrees
Re: Mugello timing
Posted: Sat May 02, 2015 6:50 am
by GP240
14 at low revs = not good, I'd be trying another stator. A Variable kit will start around 21/24 and move to 14/17 (approx).
yours being a static set-up should really stay static. Not uncommon tho, I had one static at 17 and advanced to 21 at 6k (bang) lol. I always strobe em now.
Re: Mugello timing
Posted: Sun May 03, 2015 11:54 am
by Strummer10
yes GP 240,......... I wondered if it was also an issue (hence this post). On my bikes I don't recall it moving on strobing (only on the AF lightened flywheel which is a know issue, mentioned in Stickys book and in that instant the light was disappearing on the gun then re-appearing and the arrow on the flywheel appearing at different locations against the mag flange). Could it be the pick up box on the stator, I might just try another stator. What would the consequence be of it ticking over at 14 degrees (it seems to start ok ?).
