No piston shims
Posted: Fri May 01, 2015 1:06 pm
by bogs
I've just stripped the top end on my standard sil gp 200.
There is no piston shims and a little end bearing that is smaller than the gap in the piston gudgeon area.
I have no shims but have a wider bearing to replace.
Is this ok fitting wider bearing to take up gap or do I need shims ??
Re: No piston shims
Posted: Fri May 01, 2015 1:16 pm
by barnsleybilly
I'd fit a wider bearing and not bother with the shims
Re: No piston shims
Posted: Fri May 01, 2015 10:15 pm
by rosscla
Is the crank shimmed?
If it, is then you don't need piston shims.
If it's not then you really should have shims to centralise the piston.
