Page 1 of 2
How do I get this out?
Posted: Fri Apr 24, 2015 4:51 pm
by Timbo
This has been in ever since I have had the scooter. I've been told it can be drilled out but the casing might need welding from the inside or the silencer bolt will act as a plug to stop the oil leaking... :? Anyway I'm going to have a crack :shock: myself so any tips would be appreciated. I won't be removing the engine.. :roll: ....ps the picture is taken using a mirror...
Re: How do I get this out?
Posted: Fri Apr 24, 2015 4:55 pm
by DigDug
Why Tim - do you mean to say you actually have an exhaust with a bracket that lines up with it? :shock:
Posted: Fri Apr 24, 2015 4:58 pm
by Timbo
Absolutely.......I've checked.... ;)
Posted: Fri Apr 24, 2015 6:19 pm
by shocky
Mine didnt but since I have a 110 rod and packer it does now
Posted: Fri Apr 24, 2015 6:49 pm
by PeteB
Here's what I did - it'll last for ever. Pilot drill centre of broken bolt, then progressively drill out the pilot hole and the surrounding ali to 10mm and to a depth of 20mm BUT NO DEEPER. Tap this 10mm hole out to 12mm, then screw and Loctite a 12mm bolt into the hole. Carefully cut this off flush outside the casing with a dremel, centre-dot the middle of it and drill out to a depth of 20mm MAKING SURE IT DOESN'T GO ANY DEEPER to 7mm and then tap this to 8mm using a plug tap. Voila!
Posted: Fri Apr 24, 2015 7:40 pm
by Timbo
Appreciate that Pete but more than slightly beyond my capabilities :oops: .....any easier solutions guys?
Posted: Fri Apr 24, 2015 7:45 pm
by Muppet
dot punch drill to 6.5 itll come out
Posted: Fri Apr 24, 2015 8:05 pm
by mick1
warm the surrounding area and use dot punch (or similar) to try and tap it anti-clockwise.
Try an "Easy Out" (I've had mixed fortunes with these).
Posted: Fri Apr 24, 2015 8:27 pm
by Grumpy225
You'll probably find that bolt will be super hard steel. This is due to the years of heating and cooling it's been exposed to.
Also doing that job with the motor is in the frame will be near impossible to do correctly. Center punch and then use a left hand drill bit to remove the broken piece. Follow up with a 8mm tap and you should be good. the trick will be to make sure the hole is centered and straight.
Posted: Fri Apr 24, 2015 9:09 pm
by Chris in Margate
I bet you wish you'd never asked now. Lay down for a while; the headache will go.
