GT186 - 4.6 or 4.89 final drive and which exhausts?
Posted: Tue Apr 21, 2015 3:20 pm
OK chaps, at a point in the build where I can't decide on my gearing.
Basically it's already got a LI150 gearbox and 46 tooth rear sprocket.
Now, if I go 16 / 46 I end up with 4.89 final drive and I think i already have a stretched 80 link chain.
However if i go for the 17/46 I can get a 4.6 final drive and need to get a 81 link chain.
(I could go 4.8 ratio but then thats a 48 rear / 17 front and 82 link chain and not sure if its much advantage over the 4.89)
The big question is, which exhausts will suit which set up?
OK, I know some will ask what type of riding do you do, and basically im always one up, albeit 16.5 stone. I wan't it to be quick up through the gears to have a bit of a razz but not be running it's nuts off on dual carraigeway / motorway on the way to or from a rally. Mind you, with the lads I run with I won't be sitting anywhere over a genuine 70mph.
Oh and im running a 30phbh, wassell and mtech unit if that makes any difference.
