6 Volt stop and tail bulb blowing
Posted: Tue Apr 21, 2015 12:38 am
by Lamaddict
GP 125, AF 175 kit on with a big bore. Running on points which are great and the regular 6V system. It goes great but blows the back bulb, they just get so bright with the revs. I put on a lucas diode onto the stop lamp which stops that filament blowing but the back light pops. Any ideas? 12 volt is too dim and drains power from the front lamp.
Re: 6 Volt stop and tail bulb blowing
Posted: Tue Apr 21, 2015 12:45 am
by scooterslag
AC or DC? If AC I'd personally plumb in a 12 volt regulator and change all my bulbs to 12 volt as well, works well
Posted: Tue Apr 21, 2015 2:37 am
by Lamaddict
AC DL 125 Recent Italian import.
Posted: Tue Apr 21, 2015 9:01 pm
by sunrisemac
I've just put in a 12v regulator etc for the very same reason and it seems to work well, also fitted a 12v DC horn
Posted: Tue Apr 21, 2015 9:21 pm
by Lamaddict
That's interesting. I take the 6V bulds still worked?
Posted: Tue Apr 21, 2015 10:19 pm
by YAMLAM
you need to change the bulbs to 12v.
Posted: Wed Apr 22, 2015 1:38 am
by Grumpy225
Typically bulb blowing is caused by poor grounding.
Tail/brake light to frame
headlight through headlight ring
Speedo lamp (12v) through speedo cable
motor to frame to coil
I like to add a ground cable from the speedo bulb holder to the handlebars and the headlight (white opposite of the yellow). I've also found that once one lamp goes the others will soon follow due to it being a balanced system.
Posted: Wed Apr 22, 2015 7:18 pm
by sunrisemac
Lamaddict wrote:That's interesting. I take the 6V bulds still worked?
all bulbs changed to 12V and a slight mod to get a dc feed for the horn which was originally a 6v AC ,(sounded like a 'strangled duck' )
