Carb Issues
Posted: Mon Apr 20, 2015 10:18 am
I have changed my engine spec a bit and I'm trying to dial in my jetting
The spec is
210 Malossi
Sip Head
60m crank
RD reeds
JL RH Exhaust
Fuel pump
Mtech
Lightened Flywheel
28mm Dellorto
50 Pilot
x2 needle top clip
AS 264 Atomiser
40 Slide
140 Main Jet
Air Filter
This Scooter flys and the problem is when at full throttle if I roll of the throttle it pinks like mad. I have tried Riching up the mid range by dropping the needle clip but it makes it to boggy but helps with the pinking. I have ordered a x7 needle and going to use AV atomisers question is is this the correct way to go. Something tells me I need a better carb??????????
The spec is
210 Malossi
Sip Head
60m crank
RD reeds
JL RH Exhaust
Fuel pump
Mtech
Lightened Flywheel
28mm Dellorto
50 Pilot
x2 needle top clip
AS 264 Atomiser
40 Slide
140 Main Jet
Air Filter
