Page 1 of 2
Trunnions
Posted: Sat Jun 13, 2009 2:43 pm
by bicboy
Hi there, could anyone help me. Just finished my series 2 and i keep having trouble with my Trunnions slipping, anyone out there got any advice...
Re: Trunnions
Posted: Sat Jun 13, 2009 3:40 pm
by lammydave
bicboy wrote:Hi there, could anyone help me. Just finished my series 2 and i keep having trouble with my Trunnions slipping, anyone out there got any advice...
make sure the small washer/shim is inside ....
Re: Trunnions
Posted: Sat Jun 13, 2009 10:21 pm
by drew2
its better to have a washer either side of
the cable
Re: Trunnions
Posted: Sun Jun 14, 2009 12:07 am
by J1MS
drew2 wrote:its better to have a washer either side of
the cable
The thought of doing this had never entered my head, but I do believe you are right.... from now on I will be fitting two... It will make for a more secure grip on the cable and the use of the two soft brass washers wont damage the cables as much... 8-) 8-) Top Tip Thanx...
Re: Trunnions
Posted: Mon Jun 15, 2009 6:25 pm
by cryogenic
Broady`s trunnions come with two washers so they grip the cable and don`t cut in to it ;)
Re: Trunnions
Posted: Mon Jun 15, 2009 7:01 pm
by red
Any idea where you can get the washers on their own?
Re: Trunnions
Posted: Mon Jun 15, 2009 7:14 pm
by MarkH
http://lambrettaspares.com/spareparts/c ... p0232.html
MB, but I'm not sure if they fit just their trunnions or others as well.
Re: Trunnions
Posted: Tue Jun 16, 2009 12:08 pm
by J1MS
cryogenic wrote:Broady`s trunnions come with two washers so they grip the cable and don`t cut in to it ;)
Brass washer..?? Surely they wouldnt be useing stainless washers as these would cut into the cable a little more than the softer brass which would grip better and preserve the cables longer.... ;)
Re: Trunnions
Posted: Tue Jun 16, 2009 4:45 pm
by Monty
The problem seems to be that the set screw hole is deeper than the cable pass through hole in a lot of trunnions so with one washer you are still cutting the cable strands when you tighten it up. If you can get an extra washer in and still be able to pass the cable through that would help. I dug out a set of originals that i had just cut off, the brass body's cleaned up and were perfect and the set screw was not corroded in any way and still had the washers. Not bad for 45 years
Re: Trunnions
Posted: Tue Jun 16, 2009 9:25 pm
by Knowledge
If you buy a strip of brass rod (cylindrical), you can cut it to length and use it to protect the cable. You can buy such rod at good model shops, or off epay.
