Seizure on a cast barrel
Posted: Sun Apr 12, 2015 7:20 pm
Guys,
Just wanted to float this one for a few ideas on causes. Lambretta 150 barrel, bored out to a 175 cc on an otherwise standard set up using a Jetex carb through airbox. Bike was recently rebuilt with new bearings, seals, chain and piston and rings on existing 175 bore, but otherwise nothings changed from the original set up which ran fine.
The chap has however, had a few instances where the bike has died and he said it felt like the engine was just dying going up hills (but initially not locking up) almost as though someone had merely turned off the ignition. We therefore suspected fuel starvation and sure enough there was an issue of sorts in that the petrol pipe was bent under the fuel tap and again onto the Jetex carb. A side outlet tap and new petrol pipe was fitted (and he has added in-line filter) but it seems petrol flow is fine.
Since the above done it seized again today, but this time he said the back wheel locked up and he pulled the clutch in (I suspect it was a heat seize and that this happened before perhaps and he just didn't understand the mechanism of a heat seize cos he said it was just like before). When built we set the rings at Sticky's (0.2 I think it was or 0.02, anyway the minimum ring gap commented in the book) and timing was set at 19 degrees (as book states ideal for non-tuned).
I can only think it's either the ring gap is too tight (he run in for 100 miles the new rings) or maybe timing, any thoughts ? We are going to strip the top end to see what scoring is apparent and whether we can get away with a rub-down or its a new piston. I have said go Mugello, but he wants to stay cast ...
Thanks
Thanks
