Vespa clutch cover
Posted: Sun Apr 12, 2015 1:51 pm
by southbank32
Hello there lads,on my P200E, the threads on the three bolts that hold the clutch cover in place,have stripped and will not tighten up,anybody any ideas on how to solve this problem,thanks..
Re: Vespa clutch cover
Posted: Sun Apr 12, 2015 1:59 pm
by lambro
Helicoil is the easiest fix, or tapping out to 7mm.
I prefer to helicoil though.
Shaun.
Posted: Sun Apr 12, 2015 2:14 pm
by southbank32
What size helicoil is it,M6 or M5
Posted: Sun Apr 12, 2015 2:54 pm
by gaz_powell
the original thread is m6 - I`d helicoil - you can buy a kit for less than a £10 (its a common size so wont come in wrong)
nowt wrong with helicoils in the right situation and done correctly
this is ideal with minimal work and cheap materials
when finished don't over tighten the bolts or you could put studs in and use nuts
good luck
