Fast flow tap jetting
Posted: Fri Apr 10, 2015 9:09 am
by jock11
Anybody know if you have to change jets after fitting a fast flow tap? Since fitting takes about 20 kicks to start and Now getting a lot of flooding issues
Re: Fast flow tap jetting
Posted: Fri Apr 10, 2015 9:15 am
by Chris in Margate
You could be "overcooking" the throttle when trying to start OR float is faulty. Check float is closing needle valve and do NOT use throttle when kicking over because it will flood.
No impact whatsoever if originally jetted correctly.
