Knocking Noise Related to Clutch
Posted: Fri Apr 03, 2015 6:14 pm
by Lamaddict
I put a SIP clutch into my standard Rally 200. The engine makes a knocking noise at tickover, it stops when I pull the clutch in. I've tried to adjust it but then the kickstart slips etc. Any idea what the problem is? where to fix it and can I ride it okay in the meantime. It starts and runs great.
Re: Knocking Noise Related to Clutch
Posted: Fri Apr 03, 2015 9:26 pm
by hobospeed
Have you taken the clutch cover off to see if there are any telltale signs of the clutch bell or bottom plate rubbing/knocking on the ribs on the inside? With some clutches you need to grind the ribs down a bit to make sure there is clearance. Also make sure the clutch is seated fully on the crank and the nut is tightened correctly.
Posted: Fri Apr 03, 2015 10:03 pm
by lambro
Cosa clutches (which I am sure the SIP one is) do rattle on tickover more than the old school 7 spring ones.
Most likely nowt to worry about.
Shaun.
Posted: Fri Apr 03, 2015 10:08 pm
by rosscla
Just satisfy yourself that the flywheel isn't moving in and out when you engage the clutch, can sometimes be a sign of worn main bearing.
Posted: Fri Apr 03, 2015 10:36 pm
by goldeneye
lambro wrote:Cosa clutches (which I am sure the SIP one is) do rattle on tickover more than the old school 7 spring ones.
Shaun.
this. Cosa clutches can rattle a bit.
