Rear hub bearing question.
Posted: Wed Apr 01, 2015 2:56 pm
by Minority
Just doing some work on a mates scooter and noticed that the rear hub bearing is sticking a fair way out the casing.
I know it doesn't sit flush, but is there a maximum amount it should be proud of the casing?
Last person who worked on it obviously didnt believe in using a torque wrench resulting in 4 bent studs and a bent bearing retainer plate :roll:
Re: Rear hub bearing question.
Posted: Wed Apr 01, 2015 3:42 pm
by Daggs
From memory it sticks out about 1mm maybe 2mm max.
People so often overtighten the retainer nuts/studs. They just need nipping up, use nylock nuts or spring washer/plain nuts.
Posted: Thu Apr 02, 2015 11:31 am
by Minority
Thanks for that confirmation, 1.5mm in this case :)
