Mag Housing circlip seat
Posted: Wed Apr 01, 2015 12:32 pm
by karmsemaj
Hi All I need a little advice please. I've started to strip my engine in preparation for having the casings aqua blasted before a complete rebuild, apart from a broken engine case stud everything has come apart quite easily. I came to remove the flywheel side bearing from the mag housing and noticed that there was a fracture in the metal around the circlip seat, as I removed the circlip, the damaged parts broke off.
I'm inclined to find a replacement as it holds a bearing in place but what do you guys think?
http://www.flickr.com/photos/132271324@N06/16799423240/
Re: Mag Housing circlip seat
Posted: Wed Apr 01, 2015 12:57 pm
by Daggs
That's a fairly significant piece missing. I would plump for a replacement. Unless you know anyone who can ally weld it, then machine it tidy on a lathe.
Posted: Thu Apr 02, 2015 8:49 am
by karmsemaj
Thanks for the reply, that was my thoughts too but I wanted to ask the question anyway. Could someone tell me are the mag housing the same on all series 3 or do I need to find a specific one, I'd like to get an Innocenti one if possible?
Thanks again
Posted: Thu Apr 02, 2015 9:21 am
by Muppet
ticking timebomb
Posted: Thu Apr 02, 2015 10:40 am
by Daggs
karmsemaj wrote:Thanks for the reply, that was my thoughts too but I wanted to ask the question anyway. Could someone tell me are the mag housing the same on all series 3 or do I need to find a specific one, I'd like to get an Innocenti one if possible?
Thanks again
Series 3 are the same. Getting an Innocenti one will mean secondhand. You'll need to be careful that it's better than what you have. SIL are o/k if a little rough at the edges.
Posted: Thu Apr 02, 2015 11:24 am
by karmsemaj
Thanks Daggs, much appreciated
