Advice on fitting new fuel tap needed
Posted: Tue Mar 24, 2015 11:34 pm
by alanscottj
I have tried to fit a new fuel tap after my old one started leaking. Unfortunately I have broken the nut that you have to tighten up. I am wondering if there is anything that I can use to make sure the seal around the screw on part is sealed so I don't have to tighten it so tight that I break it again!
Re: Advice on fitting new fuel tap needed
Posted: Tue Mar 24, 2015 11:44 pm
by shocky
I used a brass nut off an original fuel tap im swapping over to a new scootopia fastflow tap if thats ok ill post you the nut
Posted: Wed Mar 25, 2015 12:11 am
by Timbo
Think you might be doing it wrong as you don't have to tighten it very tight...there is a nack to doing it as I discovered at the weekend...
Posted: Wed Mar 25, 2015 9:54 am
by alanscottj
shocky wrote:I used a brass nut off an original fuel tap im swapping over to a new scootopia fastflow tap if thats ok ill post you the nut
Thanks Shocky for the kind offer but I have already ordered a new one should be here in the morning. Nice one though
Posted: Wed Mar 25, 2015 9:55 am
by alanscottj
Timbo wrote:Think you might be doing it wrong as you don't have to tighten it very tight...there is a nack to doing it as I discovered at the weekend...
Can you describe the knack?
Posted: Wed Mar 25, 2015 10:13 am
by Timbo
Probably not...
....but you should be able to hand tighten it and adjust so that the petrol tap lever sits behind the carb and then tighten with half a turn, trial and error...good luck..
Posted: Wed Mar 25, 2015 11:15 am
by shocky
alanscottj wrote:Timbo wrote:Think you might be doing it wrong as you don't have to tighten it very tight...there is a nack to doing it as I discovered at the weekend...
my sherona ..... taxi
Posted: Wed Mar 25, 2015 11:46 am
by bristolmod
remembering that it is a left hand thread and that the nut should engage on the tank AND the tap at the same point. The nut will only fit one way.
Posted: Thu Mar 26, 2015 12:04 pm
by alanscottj
Cheers guys, new one should be here today so I shall try again and try not to over tighten the thing
