My Li150 S2
Posted: Mon Mar 23, 2015 5:30 pm
Hi, bit of a long 1st-post here, hope that's ok. Being a new guy round here I'm not sure what the done thing is, but hopefully you like some pictures. I got a couple of questions at the end.
Had a delivery from LambrettaFinder on Saturday:
The frame number dates it as 1961 and I've got to say I'm really pleased with it. Obviously a whole load of work to do, but considering its age everything on it is remarkably straight. NOVA form done, and time to get the spanners out.
After sitting and looking at it for a while it was quite clear that I need to strip the whole thing down and see what lurks beneath, as various bits were very lose and falling off. The engine is also seized.
The whole thing has come apart quite easily really, not too many sheared bolt heads. A lot of the fixing seem to be brass, is that common?
The underside & barrel are covered in mud & crap:
The headset has a nest in it made of mud:
Frame almost stripped, hopefully complete later on this evening:
A pile of stripped parts:
The engine eventually came out, the bolt was really stuck & needed some heat & the washer-stack-pull tip:
Even the beak is in reasonable order, just some rust holes along the front edge:
One mucky head:
Here's a view down the inlet port, water has gotten in there & I suppose that's the reason for the seize. The piston is at BDC & the bore looks ok.
The biggest surprise was removing the oil drain plug. I expected either nothing or black gunge, but clear new-looking oil came out. Under the chain case it looks quite good:
The clutch and chain look to be in pretty good shape:
What do you think of these chain guides, do they look in good shape?
I wonder if the engine was rebuilt before the scooter was stood up, the back wheel bearing feels perfect with no play. I'd say it's not been used in many years. So I'm thinking:
- Try and get the barrel moving to unseize it & see what state the crank is in (I'm assuming I'll need to change seals at least)
- Dismantle clutch & check gearbox end-plate, bearings & clearance, change rear seal
- Complete the frame strip & start cleaning it up, decide what I'm doing with paint or 'sealed patina' kind of thing
Any suggestions or comments gratefully received.
All the best,
George.
One mucky head:
All the best,
George.
