Exotic German Pipes
grimspeed
Main scooter: gp 283 kx
Im building a new T5 motor.
60mm bell Crank with 115 blade rod from Mito . 65mm bore polaris piston .
130 / 190 port timings.
I feel that with the long stroke the charictoristics of this engine will
be more akin to a high end P2 Malossi .
So im looking for a pipe to suit .
I was thinking
https://www.scooter-and-service.de/larg ... e-curley-s
or
http://www.microsofttranslator.com/bv.a ... r-220.html
Any thoughts ?
I know I would have to change the stubs but that's not a problem !
Svint1
Hi
Send a mail to Marco at Pipedesign and tell him the setup of your engine.
-he'll revert with what pipe that suits your engine best...
I've done that several times with very good result!
Ø
President of Roughnecks Scooterclub
http://www.Roughnecks.no
1965 Vespa SS180 (218)
1971 Vespa 90 Racer
1986 Vespa PX250 (250 Rotax on CNC casings)
1987 Vespa PX210 with Cozy Sidecar
soulboy
is that crank off the shelf as im on the look out for a good race crank
grimspeed
Its a 60mm mazza bell crank with a different big end pin different rod and spacers !
http://www.wasp-performance.co.uk/onlin ... X200E.html
http://www.mitolambretta.com/product_in ... cts_id=274
And a big end pin from Martin Cook at Chiselspeed !
