SIP digital speedo in an S1 headset
Posted: Thu Mar 19, 2015 8:56 pm
by wrekkah
Has anyone successfully installed an SIP S1-2 digital speedo in an S1 headset without modification? The speedo body is hitting my gear change pulley and doesn't allow me to screw down the headset top.
Thanks
Re: SIP digital speedo in an S1 headset
Posted: Thu Mar 19, 2015 11:30 pm
by Grumpy225
Is the pulley shimmed out too close to the speedo?
I'm hoping it's an easy fix because my next project is a S1 and will have the SIP speedo.
Posted: Fri Mar 20, 2015 2:50 pm
by wrekkah
I only used one shim to fit the gear change pulley and the cable alignment looks good. Looks like I need to break out the dremmel or make a spacer to fit under the speedo bezel to raise the speedo up. Not much room in these S1 headsets especially with the front brake hydraulic line running through it!
Posted: Mon Mar 23, 2015 7:45 am
by wax
I am planning a similar installation on my S1, so any further info would be appreciated. Maybe even a photo [FACE WITH STUCK-OUT TONGUE AND WINKING EYE]
Posted: Thu Mar 26, 2015 8:40 pm
by wrekkah
As a follow-up - by changing the shims on the gear change rod and turning the Speedo slightly to match the angle of the gear change pulley I was able to fit the headset top. So it takes some fiddling but I didn't have to break out the Dremmel.
