Lambretta Cutting out ?
Posted: Sun Mar 15, 2015 10:14 am
by Strummer10
Guys, just thought I would float this one..................rebuilt lammy engine on a mate's scoot, runs and starts fine but on occasion it has just cut out, almost as though someone has turned the key off on the ignition. He says he hears a kinda tingling sound just before it cuts out. Its a standard steel barrel 175 running a 'Jetex'
Does this sound like a heat seize (wouldn't have thought so as he said it's not locking up on the back wheel or he has to pull the clutch in). Any suggestions ?
Thanks
Re: Lambretta Cutting out ?
Posted: Sun Mar 15, 2015 10:30 am
by coaster
Not much to go on Strummer, does it start again once he's stopped? You could:
Check the readings on the green and red from the stator
Fuel flow into the carb.
Check that the tank breather isn't blocked.
Try disconnecting the kill switch
Colin
Posted: Sun Mar 15, 2015 2:28 pm
by joeswoonara
maybe he has Tinnitus
or maybe be the LT coil or the Pick up, tends to happen once it`s warmed up
Posted: Sun Mar 15, 2015 2:47 pm
by PeteB
The "tingling" noise could well be pinking/preignition caused by the loss of fuel flow - effectively causing the engine to run lean for a few seconds before the fuel supply is completely lost. So perhaps start with checking the fuel tap flow, fuel cap breather, carb filter and the float needle first.
Posted: Sun Mar 15, 2015 4:34 pm
by Donnie
The fact you've put jetex as "jetex" indicates no one has bothered to rejet after building?
Posted: Sun Mar 15, 2015 5:58 pm
by shocky
Isit a 200 jetex and check theres a gasket on the slide cover
Posted: Sun Mar 15, 2015 6:10 pm
by Adam_Winstone
Pinching the fuel pipe against the top of the flywheel cover when off the stand and with him sitting on it?
Posted: Sun Mar 15, 2015 6:54 pm
by Strummer10
Thanks. Colin yes it starts immediately after pulling over and him kicking it over again and then all fine again. Timing was set to 19 degrees BTDC (as Sticky's book suggests)........, does sound (as he describes pinking might be occurring). A few mates in the past have had issues with the Jetex carbs which we thought might be a problem.......and when slammed on delortos found to be ok again. Thanks ALL for suggestions will try each one and see. Cheers.
