Jetting following reed valve- expected increase, but really!
alanscottj
My scoot was dynoed by Readspeed and was running a 108 main (muggy 198), power jet was always closed, recently fitted reed valve and was expecting to up jet as recommended. Tonight, I have managed to up jet to a 118 with power jet open 3/4 a turn. Scoot is running fantastic, nippy low down as before, sits nice at 65. I'm not looking for a problem but does this sound quite a large up jet? Or is it about right? (Plug chops to be done tomorrow)
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox πŸ˜ŽπŸ‘
Speed Demon
Yes, expect a massive upjet on reed.
Get to SULK
alanscottj
Speed Demon wrote:Yes, expect a massive upjet on reed.
So that's my main up jetted, will my needle/atomiser etc need changing too?
The dyno is the best place to get it set up but found that it was the main and needle position that needed changing on my Indian 225 when I fitted an MB reed block to it with holes in the piston and a finger port added. I believe it is compensation for poor airflow as the revs rise or somesuch :?
alanscottj
Main jet has been increased from a 108 up to a 122, PowerJet is 3/4 open and still no sign of getting boggy at wot. Plug is still a light shade of chocolate. Going to borrow some bigger main jets off a mate and see what is the biggest I can get it to then work back down.
alanscottj
Up to 128 main now! Plug is looking nice though :D
Norrie Bodge
alanscottj wrote:Up to 128 main now! Plug is looking nice though :D
Ordered my new 30mm PHBH with 125main for starters
Should be here Monday ;-)
What you got timing set at Alan?
alanscottj
Honestly can't remember mate, pete at PSL set it last time I had scoot dynoed, 17 or 18 rings a bell ?
Norrie Bodge
Ok cheers m8
I've set mine at 18 ill see how it goes ;-)
