Damaged reeds?
Posted: Sat Mar 14, 2015 10:13 pm
I went to start my TS1 this morning and on first kick there was a really loud backfire. Second kick it started fine. Is this a sign of damaged reeds?
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
That's why I'm asking the question. I recently had to replace my LT coil. When I put the flywheel back on the light wasn't that good and I knocked the woodruff key out. It stuck between the magnets on the flywheel and I spent an age trying to get it my scooter to start knowing I had a good spark. It was only when I had two really loud backfires trying to start it I found the problem. Once the flywheel was back on in the correct position it started fine and I took my scooter out last weekend and didn't have any problems, but yesterday's backfire got me thinking I might have a problem.Cereal GY wrote:My last backfire spat one of the reeds back into the carb mouth! If it misfired, I'd be checking the woodruff key and timing set up first. The damage to the reed would be a consequence of the timing issue.
