pulling my hair out ..t5
Posted: Sat Mar 14, 2015 2:16 pm
by soulboy
been having a few problems with it ..now ive put a new 26mm carb on and still av the problem it runs fine then just stops as if the ignition as been turned off or the petrol as been turned off please please help don't no weather its electrical or fuel
Re: pulling my hair out ..t5
Posted: Sat Mar 14, 2015 3:05 pm
by Norrie Bodge
IMO sounds electrical
process of elimination...
1. new plug
2. HT-lead
3. CDI-Unit ( borrow one of a mates working bike )
4: Pick-up on stator
Posted: Sat Mar 14, 2015 3:15 pm
by mick1
My guess fuel.......Sounds like the bowl is emptying and not filling fast enough. With it being 26mm have you put a fast flow tap on?
Posted: Sat Mar 14, 2015 3:21 pm
by tony172
i had this on my t5, was the pick up on the stator plate. swapped that and solved the problem. hope its that easy for you
Posted: Sat Mar 14, 2015 4:11 pm
by soulboy
cheers tony
Posted: Sat Mar 14, 2015 4:12 pm
by soulboy
mick1 wrote:My guess fuel.......Sounds like the bowl is emptying and not filling fast enough. With it being 26mm have you put a fast flow tap on?
yes mick ive got a fast flow on it
Posted: Sat Mar 14, 2015 5:41 pm
by sean brady scooters
have you checked out the readings from the stator ?
Posted: Sat Mar 14, 2015 7:58 pm
by gavi4t
check your fuel pipe is the right length if its too long this will happen
Posted: Sat Mar 14, 2015 8:26 pm
by lockman69
^^^^ what he said, did you change the fuel pipe?
Posted: Sun Mar 15, 2015 5:44 pm
by soulboy
