vespa t5 engine mount
crispin
Main scooter: vespretta chopper
Got my new front engine mounts for my t5.
Went to put them in and the one nearist the engine is to wide by about 4mm.
Looked at the old one and it is smaller than the new one and smaller than the one on the opposite side.
The washer in the engine mount is right back and the rubber is pushed back against it so it will not go in any further.
So got the dremel on it fits fine now but just wondered if this is a common problem.
Got bits from beed speed and they said this is a first.
Anyone else had this :?:
gaz_powell
T5 and P200 mounts are the same size both sides.
If you have a large and smaller mount it sounds like its a px125/150 casing.
crispin
Its got centre plug hole on barrel.
And 2 bolted exhaust studs on engine case
    Users browsing this forum: Ahrefs [Bot] and 4 guests
