Page 1 of 4
200 cylinder to small block conversion?
Posted: Fri Mar 13, 2015 4:30 pm
by Chris Tindal
Hello
Does anyone know of a dealer/engineer in the West Yorkshire area that will convert a GP200 cylinder and head for a small block casing? Oiltech only convert casings. If anyone fancies the job or knows anyone please let me know.
Re: 200 cylinder to small block conversion?
Posted: Fri Mar 13, 2015 5:19 pm
by hungdog
Posted: Fri Mar 13, 2015 5:41 pm
by cgt75b
I think you are talking about turning down the spigot, and opening up one of the stud holes ?
Posted: Fri Mar 13, 2015 5:43 pm
by DigDug
It would probably cost you as much as sorting a small block to suit the cylinder.
Posted: Sat Mar 14, 2015 12:02 am
by Grumpy225
That sounds like the hard way to do it.
Why not just long stroke a 65mm bore?
a 60mm stroke crank will give you 199cc on a 65mm bore with no case or cylinder mods.
Posted: Sat Mar 14, 2015 3:35 am
by Chris Tindal
hungdog wrote:?
Turning down the spiggot and drilling the stud holes to 13/14 mm allows the 200 cylinder to be fitted onto a small block casing. It's straightforward, if anyone knows who can do it let me know.
Posted: Sat Mar 14, 2015 3:37 am
by Chris Tindal
Grumpy225 wrote:That sounds like the hard way to do it.
The bottom end is already built with the original 1970 crank.
Posted: Sat Mar 14, 2015 11:25 am
by ktmh5
Tried Chiselspeed?
Posted: Sun Mar 15, 2015 11:35 am
by Chris Tindal
I'll give Chiselspeed a call Monday, cheers.
Posted: Tue Mar 17, 2015 10:28 pm
by Chris Tindal
Had a reply from Chiselspeed, they will convert 200 cylinders to small block.
