Rack fitting question
Posted: Thu Mar 12, 2015 6:58 pm
by Nerdy Norm
A bit of a basic one I hope!
When fitting a 3-in-1 rack to an S3, does the rack mounting section fit under or over the seat latch?
Re: Rack fitting question
Posted: Thu Mar 12, 2015 7:18 pm
by rosscla
I'd put it under or the seat might not catch, and it might not anyway but that depends on the rack ;-)
Posted: Thu Mar 12, 2015 7:19 pm
by Donnie
not had one for a while but believe I fitted mine under the seat plate
Posted: Thu Mar 12, 2015 7:42 pm
by Nerdy Norm
Thanks chaps - sod's law, I've fitted it over the seat catch, mainly because the catch is already shaped to fit the curve of the bodywork, whereas the rack is flat. As expected, the seat doesn't latch down, but then again it never did unless I fiddled around with it.
Posted: Fri Mar 13, 2015 5:45 am
by ulyssescale
And if the back of the seat gets raised enough so that the seat can rock from side to side whilst your butt is on it - the hinge at front of seat will crack.
Posted: Fri Mar 13, 2015 8:13 am
by Nerdy Norm
That's an interesting point. At the moment, the seat catch is in the same position it was before (sitting directly on the frame), so I maybe it's better that way?
