Jetting mates Imola!
Posted: Fri Mar 06, 2015 6:21 pm
Mate of mine had a new exhaust (unknown origin, see piccies below) fitted a few months ago but hasnt rejetted. He says it flies, I kept saying they all do 'til they go pop!
Of course that only means he's finally thought he'd give it to me to jet! Should've kept me gob shut
mind you, he is a good mate and I don't want to be on a run with him broken down and thinking I could have prevented that.
Anyway, it's an imola 186, 30 PHBH open mouth, and as I say unknown expansion chamber, similar to JL3 but no rear support and a one piece ubend unlike the JL's which have a seperate stub and ubend. So if anyone can identify the exhaust I'd be grateful.
Other than that I've never jetted an imola so am unfamiliar with the rough jetting though found the following on the Bristol lambretta site which was handy and close to whats in it.
ie. Lambretta Imola 185 with Dellorto 30mm PHBH and Imola snail
Atomiser AS266/Needle X2 /Main 135 +/Pilot 55 - 60/Slide 40
Now, the scooter in front of me as Atomiser AS266, Needle X2, Pilot of 55, choke 70, Slide 40 so pretty much as it says, however the main's only a 115! So ill be upping that for a start!!
Found this in the carb filter!
