LTH/TT Manifold
Posted: Thu Mar 05, 2015 7:27 pm
by wack 63
What tanks are people using with the short TS1 manifolds ? I tried fitting one to my GP with a SSP 13 ltr tank but the manifold is too short and not allowing the carb onto the flange rubber.
Re: LTH/TT Manifold
Posted: Thu Mar 05, 2015 10:13 pm
by joeswoonara
i use a Jimmers manifold fit perfect with my Diablo tank
Re: LTH/TT Manifold
Posted: Thu Mar 05, 2015 10:22 pm
by wack 63
I believe the Jimmers is the same so thanks for info
Re: LTH/TT Manifold
Posted: Fri Mar 06, 2015 9:08 pm
by Yanker
Looking at it from the other side (both figuratively and litteraly). I had same issue with VHSB/Rapido/Chiselspeed manifold combination. I explained it to SSP (Simon I think? it was some years back), marked it up and sent it over. He re worked the cut-out area (it needed deepening by 3/4" or so) and returned the tank f.o.c. All now fitted A1. Now there is outstanding service for you!
Re: LTH/TT Manifold
Posted: Fri Mar 06, 2015 10:17 pm
by wack 63
That's an idea ,thanks
