i need guidance QUICK!
Posted: Thu Mar 05, 2015 10:41 am
by a.j
With only hours left til Sanford my clutch is slipping. Finished bike last night. Took it out and in fourth gear overtaking is a nightmare..all revs and no go. Im running an iron 225 with new five plate clutch. Please tell me I only need to adjust it.
Re: i need guidance QUICK!
Posted: Thu Mar 05, 2015 10:55 am
by dapper
Is it the AF cassette clutch?
Posted: Thu Mar 05, 2015 11:04 am
by a.j
Readspeed five plate
Posted: Thu Mar 05, 2015 11:20 am
by WINTERMODEL150
Hi a.j.check cable isn't too tight,is bronze bush fitted correctly?is kickstart shaft rubbing on clutch top plate inside?
Dean
ps take cable off clutch lever on engine then if you can find an open road with no traffic I'd bump start it then see if it still Slips with cable disconnected.
Posted: Thu Mar 05, 2015 11:29 am
by a.j
Cheers. I'm not into the dark art of fiddling about. I can do the brutal stuff fine. I've only got an hour dinner break so I need it sorted. Will try anyway.
Posted: Thu Mar 05, 2015 1:27 pm
by dapper
I asked about the cassette clutch as when I first fitted mine, I couldn't get the clutch to disenagage. Eventually found that the threaded part of the cluster was too tall and fouled on the clutch centre when trying to compress the clutch. Ended up having to fit a different gearbox. Will have to get the extra long cluster machined or ground down a few mill.
Posted: Thu Mar 05, 2015 1:31 pm
by Toddy
a.j wrote:With only hours left til Sanford my clutch is slipping. Finished bike last night. Took it out and in fourth gear overtaking is a nightmare..all revs and no go. Im running an iron 225 with new five plate clutch. Please tell me I only need to adjust it.
Be a long 42.3 miles then
good luck with it mate , do the simple things first as advised clutch cable , then if not that have a look inside
Posted: Thu Mar 05, 2015 3:48 pm
by a.j
Toddy wrote:a.j wrote:With only hours left til Sanford my clutch is slipping. Finished bike last night. Took it out and in fourth gear overtaking is a nightmare..all revs and no go. Im running an iron 225 with new five plate clutch. Please tell me I only need to adjust it.
I sorted it. Adjustments all done. Sleep easy lads....sleep easy.
Posted: Thu Mar 05, 2015 7:56 pm
by Timbo
........phew....
Posted: Fri Mar 06, 2015 12:49 am
by Trojan
Happy Days, i ll go back to sleep now
glad to see its sorted.........
