BGM cylinderhead
Posted: Tue Mar 03, 2015 12:01 pm
by Minority
Thinking about using a cylinder head that sits into the cylinder like the BGM kit. Does anyone know how deep the recess on the BGM head is?
Also is the contour for the standard lambretta piston?
Thanks in advance :D
Re: BGM cylinderhead
Posted: Tue Mar 03, 2015 12:13 pm
by shocky
Posted: Tue Mar 03, 2015 12:14 pm
by shocky
It states the drop as 5mm on the head
Posted: Tue Mar 03, 2015 1:20 pm
by Minority
Thanks for that, does anyone know if there are any other options to do this?
Posted: Tue Mar 03, 2015 5:52 pm
by jason frost
You can do it with most heads, how have you ended up with the piston so low in the barrel ?
Posted: Tue Mar 03, 2015 11:30 pm
by Minority
Piston isn't quite that low Jason, but squish is coming up at 1.5 -1.6 with no head gasket. I was also thinking of maybe raising the cylinder another .5mm to give a bit more transfer & exhaust timing.
Just thinking about options rather than machine the cylinder, better cooling, better squish design, plug position etc. Down side would be multiple head gaskets needed, as far as I can see, if the drop into the cylinder is 5mm
Posted: Wed Mar 04, 2015 8:52 am
by jason frost
BGM do a head for TS without the drop that you could use, not sure if they do blanks.
