Page 1 of 2
Oil drain thread
Posted: Mon Mar 02, 2015 7:10 am
by stonerosesmod
A mates bought round his PX200 engine for me to give a once over internally and he said the gear oil drain plug threads are knackered.Whats the easiest fix here? Could i tap out to the next size or even M8 and use an appropriate fibre washer?
Re: Oil drain thread
Posted: Mon Mar 02, 2015 11:05 am
by GLscoot
The thread is already M8, its just you need a M7 socket head to remove it. I would try and keep it M8, the next common size up is M10, not a lot of M9 suppliers out there unless you go imperial.
Posted: Mon Mar 02, 2015 6:58 pm
by Shaunbond
You might be able to get away with an M8 helicoil. I'm not sure which pitch it is but no real difference in drill size.
http://www.thorintl.com/Drill-Sizes-Hel ... tric.shtml
Posted: Tue Mar 03, 2015 7:08 am
by stonerosesmod
Yes i think thats the way forward.Cheers lads
Posted: Tue Mar 03, 2015 8:12 am
by ducksta
Similar advice required my m8 has stripped the threads on a px200 its the hole in casing where you fastern the carb down any suggestions ime off to have a look tonight but was thinking would a collet be any good
Posted: Tue Mar 03, 2015 11:38 am
by GLscoot
ducksta wrote:Similar advice required my m8 has stripped the threads on a px200 its the hole in casing where you fastern the carb down any suggestions ime off to have a look tonight but was thinking would a collet be any good
Im sure thats M7 so could be retapped to M8.
Posted: Tue Mar 03, 2015 1:41 pm
by Shaunbond
Same thing happened on my Cosa. I helicoiled that but I'm sure it was M7.
Posted: Tue Mar 03, 2015 4:38 pm
by ducksta
will re tap to m8
Posted: Tue Mar 03, 2015 9:34 pm
by gaz_powell
The carb bolt thread in the casing is 7mm - don't forget if you tap it to 8mm you will have to do something with the stud and sleeve bolt (early) or shouldered bolt (later)
Posted: Tue Mar 03, 2015 10:07 pm
by Shuggie
Beedspeed do a stepped stud, 7mm on one end 8mm the other, just tapped casing to 8mm and it worked a treat! Think its soldas a lammy chaincase stud
