What The Fuel (WTF)!
Posted: Sat Feb 28, 2015 11:58 am
So, having a number of bikes there comes a time when some bikes get used less than others. Probably as long ago as 6 months, I parked up this bike in a perfectly reliable and road-worthy state and now the time has rolled around for me to MOT it again. Although I knew the battery for the original 6V DC system was failing to hold charge for long, I decided to give it the once over and ensure that my battery charger had put enough into it for the active supply when running to power the horn and brake light.
This morning I got up early to check that all was well for me to try and get it in for an MOT, only to find that the bike wouldn't start. Funnily enough, it did fire a couple of times (I kid you not) so I thought it might burst into life after a few more kicks, then a bump... but no
Lift the seat and check fuel in tank (fine). Panel off to see that fuel is visible in the clear fuel line (fine). Swap out plugs again, checking for decent spark (fine). After many attempts I decided that stripping the carb might be a good idea... and look what I found!!!
Bearing in mind that the fuel in the tank looks fine, as does the fuel in the fuel line, how the heck can this be the state of the fuel in my float bowl?! I had this happen once before, decades ago, when leaving my bike out the back of my digs and finding that the oil separated from the fuel on cold nights, however, this is something else! When this happened, way back when, I was using good quality Rock Oil, today's example is on the same Groundsman that I've used without issue for a number of years and have never previously had a problem with.
Is this going to be another example of the fuel changing specification?
Your thoughts very welcome.... and take this as a warning to the rest of you that leave a bike standing for any length of time (if that is a contributing factor).
Edit: All parts cleaned out, then doubled cleaned with spray carb cleaner, the fuel flows freely from the tank/tap and the bike runs fine!
