6 volt coil testing.
Posted: Fri Feb 27, 2015 9:31 am
by Ihateyoubutler
Apart from actually trying them on an engine, are there any tests that can be done on original type 6 volt ht coils to check if ok? I've got an ohm's meter, or is something else like a megger required?
Thanks.
Re: 6 volt coil testing.
Posted: Fri Feb 27, 2015 10:30 am
by bristolmod
would think substitution is the quickest way forward- just whack another one on and see what happens.
To be honest, T've never had a 6v coil fail in nearly 50 years of scootering- the problems always were further upstream in the system
