1974 Serveta LI 150
Posted: Thu Feb 26, 2015 12:24 pm
by Lammy Guy in Aus
Hi peeps what is you opinion on the Serveta LI 150 ?
Worthwhile acquisition?
Reliability of bike and engine ?
Tune ability?
Any advise welcomed.
Price would be about 1500 pounds.
Re: 1974 Serveta LI 150
Posted: Thu Feb 26, 2015 1:01 pm
by scooterslag
The build quality of servetta's are pretty good, good strong frames and engines components, the Spanish rear hub is the best to use, tuning wise? well anything from a upjet and a clubman to a full blown nutter RB kit with all the trimmings- yep worth picking up. The only problem I found was the motoplat electrics could be a bit weird, change to Italian Ducati points set up (or electronic if you wish) and you should have a great little scooter. Paul
Posted: Thu Feb 26, 2015 4:46 pm
by bristolmod
is it these that have the meatier orifice for the cylinder to slide into as well? If it is then proper "200" conversions are simpler I understand.
Chris
Posted: Thu Feb 26, 2015 9:31 pm
by Lammy Guy in Aus
Wow sounds like this is my way to go. Thanks guy's for the feed back much appreciated
Posted: Fri Feb 27, 2015 12:46 am
by shocky
bristolmod wrote:is it these that have the meatier orifice for the cylinder to slide into as well? If it is then proper "200" conversions are simpler I understand.
Chris
I think 5hats the later ones from the 80, s , also the gearbox might be the one with a big gap between 3 and 4 th
Posted: Fri Feb 27, 2015 10:28 pm
by buzzsolomoto
With regards to the engine if its a "Special" then it will probably have the larger casing
Specials have an engine number starting 3***** they were produced from 1966 onwards and most have the larger casing. if it is just the LI then it will have a number starting 06**** or 07**** some of these are the larger type but a lot less.
buzz
Posted: Fri Feb 27, 2015 10:33 pm
by mick1
Is this all based on the frame number or the engine number ? .........
Posted: Fri Feb 27, 2015 10:41 pm
by buzzsolomoto
the info is based on the engine number
however it is a Spanish scooter so the frame and engine number should be exactly matching.
buzz
