Page 1 of 2
Fitting Li ramp - need to remove end plate or not?
Posted: Sun Feb 22, 2015 10:26 pm
by alanscottj
The saga of the kickstart engaging continues and I have decided to have a go at fitting an Li ramp whilst the side casing is off. I know what I have to do and am wondering if it is possible to cut off the ramp of the end plate with it in situ. Maybe with a cutting disk on my dremel? Any thoughts???
Re: Fitting Li ramp - need to remove end plate or not?
Posted: Sun Feb 22, 2015 10:51 pm
by lambro
All those filings in your gearbox and clutch,
I wouldn't advise it.
Remove, cut, smooth and reshim gearbox.
Posted: Sun Feb 22, 2015 10:53 pm
by alanscottj
lambro wrote:All those filings in your gearbox and clutch,
Yeah, I thought about that! Haven't removed one before, a bit nervous tbh, especially as engine has recently been built.
Posted: Sun Feb 22, 2015 10:56 pm
by Adam_Winstone
Got to remove the endplate.
Posted: Sun Feb 22, 2015 11:01 pm
by alanscottj
Adam_Winstone wrote:Got to remove the endplate.
Looks like it, is it a hard job?
Posted: Sun Feb 22, 2015 11:47 pm
by rosscla
No, take the clutch off, loosen and remove the nuts and use two m6 bolts or t bars to jack it off
Posted: Sun Feb 22, 2015 11:50 pm
by alanscottj
rosscla wrote:No, take the clutch off, loosen and remove the nuts and use two m6 bolts or t bars to jack it off
I have removed the clutch plates before to replace one of the clutch centre bearings, so there's not much more to do to take the end plate off then?
Posted: Sun Feb 22, 2015 11:51 pm
by hendy
I did my first one a couple of months ago. Not difficult, just took my time and read sticky', haynes and the lcgb guide '
To be honest I spent more time reading than building my gearbox but it was worth it.
Don't be shy, get into it.
Posted: Mon Feb 23, 2015 1:47 am
by corrado
The ramp tends to stick to the xmas tree when you draw it up with the T bar extractors stopping it from breaking free so tap the xmas tree gently with copper mallet to disengage it.
Posted: Mon Feb 23, 2015 9:01 am
by rosscla
If it does stick you can also give it a tap on the rectangular lump on the end plate in front of the bearing
