Page 1 of 2
how to fit oko or glube into tubeless tyres
Posted: Tue Feb 17, 2015 9:46 pm
by joespeed
tyres are fitted how do you fit sealant into valve?valve removed ,tyre squashed but bead not broken?
whats your easy method?
Re: how to fit oko or glube into tubeless tyres
Posted: Tue Feb 17, 2015 11:01 pm
by coaster
I just follow the instructions on the bottle, remove valve, rotate wheel so that valve is near the bottom, squeeze in the required amount, clear out valve stem with something like a cotton bud and replace the valve. Rotate wheel a few times and re-inflate. The gloop will distribute itself all by itself when you start riding. No different to installing in a tubed wheel.
Posted: Tue Feb 17, 2015 11:34 pm
by joespeed
sound as easy as a b c but i cant squeeze the goo into two of these rims feels like the air is trapped ?
Posted: Wed Feb 18, 2015 12:09 am
by philz
Can you squash the top of the tyre down so that it tries to suck some in when you release it?
Posted: Wed Feb 18, 2015 12:17 am
by coaster
joespeed wrote:sound as easy as a b c but i cant squeeze the goo into two of these rims feels like the air is trapped ?
I see what you mean, if the goop is cold it will be harder but the air pressure is sometimes a problem and you need to remove the tube from the valve and let the bottle reform back to it's shape so you can get some pressure in the bottle. Try warming the goop in a bowl of hot water first.
Posted: Wed Feb 18, 2015 2:36 pm
by ForemanBob
I always knock the tyre of the beed and squirt the gloop under the tyre edge....
Posted: Wed Feb 18, 2015 5:54 pm
by a.j
Anyone got any feedback from tyre fitters who replace tyres filled with punctureseal or other such product?
Posted: Wed Feb 18, 2015 6:35 pm
by joespeed
sorted small blockage under valve hole!
Posted: Wed Feb 18, 2015 8:51 pm
by DigDug
a.j wrote:Anyone got any feedback from tyre fitters who replace tyres filled with punctureseal or other such product?
No but I'm surprised that people bother using it with tubeless tyres.
Posted: Wed Feb 18, 2015 10:04 pm
by joespeed
you would be wasting money putting it in a tubed tyre though!
