End plates
Posted: Tue Jun 09, 2009 11:39 pm
by carlos fandango
I know these are supposed to be a matching pair with the engine block.
Whats the problems fitting a random one ? Is there must of a difference?
Re: End plates
Posted: Wed Jun 10, 2009 7:48 am
by mark
i have found that endplates do vary in the fact that the layshaft bearingsd are upto 2.5mm out of line . i beleive they were machined as a pair in the factory . i had a guide made that was a straight layshaft welded into a a bearing shaped piece of steel which was then pressed into the casing and tried various endplates on , until i found one that fitted perfectly on the studs,dowels and bearing face
Re: End plates
Posted: Wed Jun 10, 2009 8:20 am
by Ian Hepworth
mark wrote:i have found that endplates do vary in the fact that the layshaft bearingsd are upto 2.5mm out of line . i beleive they were machined as a pair in the factory . i had a guide made that was a straight layshaft welded into a a bearing shaped piece of steel which was then pressed into the casing and tried various endplates on , until i found one that fitted perfectly on the studs,dowels and bearing face
That's a good idea. I've got about a dozen casings that are separated from their endplates. I now keep the endplate in the casing when I strip an engine down. You live and learn!
