172 Idle jet
Posted: Sat Feb 14, 2015 12:08 am
by wack 63
Setting up a Malossi T5 172 with a standard 24 carb and Revolver pipe and the standard idle jet needs the airscrew well out to idle correctly,anyone recommend a different jet size?
Re: 172 Idle jet
Posted: Sat Feb 14, 2015 2:41 pm
by soulboy
wack that's my set up pal and ive got a cut crank and matched and polished casings and I have no trouble you sure its that mate
Re: 172 Idle jet
Posted: Sat Feb 14, 2015 4:42 pm
by ukpeckerwood
Sounds like the idle jet is to large, thats why the air screw is out so far, but you say its the original idle jet.
Re: 172 Idle jet
Posted: Sat Feb 14, 2015 6:20 pm
by wack 63
Pretty sure airscrew out richens the mixture. The idle seems fine even with the screw 4-6 turns out but have a rich spot at 1/4 throttle with a BE3 which clears with a BE4 but the plug is dark grey with the 4 at 1/2 throttle plug chops.
