Squashed air filter
Posted: Mon Feb 09, 2015 4:54 pm
by a.j
I've got one of those Atomic scootrs reed blocks fitted and have issues with any type of filter clearance to panel. I tried one of the MB flat push on foam filters but that was no good. breathe sweet with rubber elbow is no good either... I've seen these now & they'd work, but my question is what type of foam are they made from, as I have loads of foam at home & if any old foam works I'd just use that.
cheers
Re: Squashed air filter
Posted: Mon Feb 09, 2015 6:32 pm
by rosscla
One of what?
Posted: Mon Feb 09, 2015 6:45 pm
by a.j
Posted: Mon Feb 09, 2015 7:00 pm
by Donnie
but you already said you'd tried one?
Posted: Mon Feb 09, 2015 9:15 pm
by Doom Patrol
Foam filters are a rip off. Go to a shop that does Moto X'ers and they'll sell you as much foam as you want for a darn sight less than buying a ready made item. Get a bit of glue and make your own.
Posted: Tue Feb 10, 2015 11:12 am
by dapper
a.j wrote:I've got one of those Atomic scootrs reed blocks fitted and have issues with any type of filter clearance to panel. I tried one of the MB flat push on foam filters but that was no good. breathe sweet with rubber elbow is no good either... I've seen these now & they'd work, but my question is what type of foam are they made from, as I have loads of foam at home & if any old foam works I'd just use that.
cheers
Is that the larger Atomic reed valve or the smaller one which doesn't need fins cutting?
Posted: Tue Feb 10, 2015 1:31 pm
by olliewtf
what about the flat MB one was no good? its design means it should be squashed against the panel to allow air to be drawn solely through the foam... the only negatives ive read is that they dont breath very well, but i have one im about to fit so would be interested to know what poblems you are having.
Posted: Tue Feb 10, 2015 4:14 pm
by a.j
Doom Patrol wrote:Foam filters are a rip off. Go to a shop that does Moto X'ers and they'll sell you as much foam as you want for a darn sight less than buying a ready made item. Get a bit of glue and make your own.
cheers mate.
