t5 rear hub oil seal
Posted: Thu Feb 05, 2015 8:45 am
by smoore-gt225
Hi probably a silly question :oops: but having a blank moment I have a 1985 T5 engine should the rear hub oil seal be the external type. on stripping down im sure its supposed to be external but it has an internal one fitted
cheers steve
Re: t5 rear hub oil seal
Posted: Thu Feb 05, 2015 9:18 am
by nelson pk
As far as i am aware all T5's had the internal seal and the dust thingy where the rear seal used to go on the P range.
Posted: Fri Feb 06, 2015 6:21 am
by T5-190
Steve the T5 has an internal seal and indeed a dust seal on the outside. But I always fit an oil seal on the outside too. Just a little more peace of mind, and may help oil from getting to the rear shoes. The seal is about a £1 from a bearing dealer.
Posted: Fri Feb 06, 2015 10:55 am
by fastfrog
+1 but you need a rear hub OK with external seal.
