Longer rear shocker fixing bolt needed
Posted: Wed Feb 04, 2015 11:01 pm
by Norrie Bodge
lads
does anyone know who does a longer rear damper fixing bolt?
me mate, has a JL-Exhaust fitted & the rear bracket off it fits on with the rear shocker..
there is v-little thread left to fit the nut? nevermind with a washer too?
Re: Longer rear shocker fixing bolt needed
Posted: Thu Feb 05, 2015 12:30 am
by goldeneye
ive a JL on mine Norrie, ill have a look to see if ive any bolts the same. get a full width nyloc and washer on mine.(tell him to do the vespa rear suspension bush conversion on it while he"s on, no more snapped JL rear rubbers)
Posted: Thu Feb 05, 2015 11:00 am
by Norrie Bodge
Cheers m8
what does that bush conversion need exactly Jeff
Posted: Thu Feb 05, 2015 11:06 am
by goldeneye
its a bit of stud, a rear shock bush, and a few washers and nuts etc. not a lot really. you going to A19"s at weekend? I"ll take some pics and show ya.
Posted: Thu Feb 05, 2015 4:04 pm
by gaz_powell
Gash
Early casings use a 9mm x 65mm long
Late casings use a 10mm x 70mm long
Ebay has plenty of part threaded bolts at M10 x 75 or 80 and beyond for coppers
M9 is the problem !
Posted: Thu Feb 05, 2015 4:38 pm
by Norrie Bodge
its tiny tail eggys bike gaz
we just fitted a new rear shocker & brackets must be thicker on it? its on old P2 casings so yep 9mm
Jeff - if you`ve gotta a spare longer 9mm bolt?? tiny-tail says bring it plz with ya picture ov conversion
& will get it off ya on sat night fella
Posted: Thu Feb 05, 2015 8:32 pm
by GLscoot
If its M9, then you need to get a GS150 rear shock bolt from Germany. I have tried everywhere in the UK and it seems the Germans are the only ones that have them.
http://www.sip-scootershop.com/en/produ ... k_78724060
Posted: Fri Feb 06, 2015 12:42 am
by Norrie Bodge
cheers m8
i will let me mate know
Posted: Fri Feb 06, 2015 7:33 pm
by gaz_powell
I`d change the bush and go to the 10mm - much better if you require a longer bolt - bushes/sleeve are only about six quid
then you can get the exact size bolt easily in the future
