Rear hub seal
Posted: Mon Feb 02, 2015 7:21 am
by stonerosesmod
Any tips on what to use on a PX200 EFL rear hub seal on install? Do you heat casings slightly first or should it just tap down with a socket?
Re: Rear hub seal
Posted: Mon Feb 02, 2015 11:08 am
by gaz_powell
It should go relatively easily - make sure the the casing is spotless and a thin spray of silicon grease and press home by hand or a little help with a drift if necessary i turned a hardwood solid round drift for the internal type.
Re: Rear hub seal
Posted: Tue Feb 03, 2015 1:48 pm
by stonerosesmod
Cheers Gaz,will give it a go.
